Aller au contenu principal
Acer Aspire ES1-111M-C7DE RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire ES1-111M-C7DE RAM Replacement, Back Cover: étape 1, image 1 de 2 Acer Aspire ES1-111M-C7DE RAM Replacement, Back Cover: étape 1, image 2 de 2
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 2, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 2, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 2, image 3 de 3
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE RAM Replacement, Battery: étape 3, image 1 de 2 Acer Aspire ES1-111M-C7DE RAM Replacement, Battery: étape 3, image 2 de 2
    • Locate the small black button surrounded by a white circle near the battery on the motherboard.
    • Press and hold the button for five seconds.
  4. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 4, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 4, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 4, image 3 de 3
    • Using your fingers or the small plastic opening tools, disconnect the battery connection from the motherboard by pinching and pulling back on both sides of the connector.
  5. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 5, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 5, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 5, image 3 de 3
    • Locate the two 6.2mm black screws holding the battery in place and unscrew them.
    • Gently lift and remove the battery.
  6. Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: étape 6, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: étape 6, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: étape 6, image 3 de 3
    • Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
  7. Acer Aspire ES1-111M-C7DE RAM Replacement, Network Card: étape 7, image 1 de 2 Acer Aspire ES1-111M-C7DE RAM Replacement, Network Card: étape 7, image 2 de 2
    • You will see a white rectangular piece next to the upper left-hand corner of the motherboard that is connected with a black cord and a white cord; this is the network card.
    • Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
  8. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 8, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 8, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 8, image 3 de 3
    • Remove the black and the white cords from the network card.
    • Slide the card out of the motherboard and replace it with the new one.
  9. Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: étape 9, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: étape 9, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: étape 9, image 3 de 3
    • Disconnect the remaining connectors from the motherboard.
  10. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 10, image 1 de 2 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 10, image 2 de 2
    • Unscrew the three 6.2mm screws as indicated by the picture.
  11. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 11, image 1 de 2 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 11, image 2 de 2
    • Flip the motherboard over.
  12. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 12, image 1 de 1
    • Locate the RAM
  13. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 13, image 1 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 13, image 2 de 3 Acer Aspire ES1-111M-C7DE RAM Replacement: étape 13, image 3 de 3
    • Gently push the two metal clips that hold the RAM to the side, as indicated by the picture.
    • It should pop up once done.
  14. Acer Aspire ES1-111M-C7DE RAM Replacement: étape 14, image 1 de 1
    • Pull the RAM out.
Mason Devinney
Membre depuis le 09/25/17
388 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S3-G1, Cannon Fall 2017 Membre de l'équipe USF Tampa, Team S3-G1, Cannon Fall 2017
USFT-CANNON-F17S3G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 31
Total : 1,573
