Aller au contenu principal
Acer Aspire ES1-512-C80E Disk Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: étape 1, image 1 de 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 2, image 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 2, image 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 2, image 3 de 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: étape 3, image 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: étape 3, image 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: étape 3, image 3 de 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 4, image 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 4, image 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 4, image 3 de 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 5, image 1 de 2 Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 5, image 2 de 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: étape 6, image 1 de 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: étape 7, image 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: étape 7, image 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: étape 7, image 3 de 3
    • Push the disk drive out of the side slot.
To reassemble your device, follow the steps in reverse order.
Peter Bulman
Membre depuis le 10/31/19
231 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S2-G8, Barthe Fall 2019
UMASSD-BARTHE-F19S2G8
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 15
Total : 435
