Aller au contenu principal
Acer Aspire ES1-711-P1UV Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Hard Drive Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Hard Drive Replacement: étape 4, image 1 de 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Remove the four 4.5 mm screws that hold the hard drive in place.
  6. Acer Aspire ES1-711-P1UV Hard Drive Replacement: étape 6, image 1 de 2 Acer Aspire ES1-711-P1UV Hard Drive Replacement: étape 6, image 2 de 2
    • Remove the tabs holding the hard drive in place.
    • Remove the hard drive.
3 autres ont terminé cette réparation.
Lindsay O'Shea
Membre depuis le 03/22/18
414 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team S17-G3, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G3, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 2,506
