Aller au contenu principal
Acer Aspire M5-583P-9688 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: étape 2, image 1 de 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: étape 2, image 2 de 2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: étape 3, image 1 de 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: étape 3, image 2 de 2
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
3 autres ont terminé cette réparation.
Collin Steel
Membre depuis le 01/29/18
328 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 19
Total : 1,586
