Aller au contenu principal
Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement
Ce dont vous avez besoin
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: étape 1, image 1 de 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: étape 1, image 2 de 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 2, image 1 de 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 2, image 2 de 2
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 3, image 1 de 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 3, image 2 de 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 3, image 3 de 3
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 4, image 1 de 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 4, image 2 de 2
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 5, image 1 de 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: étape 5, image 2 de 2
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
John Hasenbein
Membre depuis le 09/11/17
119 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team S1-G4, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S1-G4, Bruce Fall 2017
CSUF-BRUCE-F17S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 970
