Aller au contenu principal
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
Ce dont vous avez besoin
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: étape 1, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 2, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 2, image 2 de 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: étape 3, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 4, image 1 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 4, image 2 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 4, image 3 de 3
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 5, image 1 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 5, image 2 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 5, image 3 de 3
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: étape 6, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: étape 6, image 2 de 2
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 7, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 7, image 2 de 2
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 8, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 8, image 2 de 2
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 9, image 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 9, image 2 de 2
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: étape 10, image 1 de 1
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Joseph
Membre depuis le 01/25/18
685 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S20-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 22
Total : 1,629
