Aller au contenu principal
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 2, image 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 2, image 2 de 2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 3, image 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 3, image 2 de 2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: étape 4, image 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 5, image 1 de 1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 6, image 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 6, image 2 de 2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 7, image 1 de 1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 8, image 1 de 1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: étape 9, image 1 de 1
    • Gently pull the motherboard away from the small square chip to its left.
Hanna Flores
Membre depuis le 09/20/17
149 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 18
Total : 1,079
