Aller au contenu principal
Acer Aspire R R5-471T-51UN Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Aspire R R5-471T-51UN Trackpad Replacement, Battery: étape 1, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement, Battery: étape 1, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement, Battery: étape 1, image 3 de 3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 2, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 2, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 2, image 3 de 3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 3, image 1 de 2 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 3, image 2 de 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 4, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 4, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 4, image 3 de 3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 5, image 1 de 2 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 5, image 2 de 2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN Trackpad Replacement, Keyboard: étape 6, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement, Keyboard: étape 6, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement, Keyboard: étape 6, image 3 de 3
    • Use the spudger to flip up the locking tabs on each of the four ZIF cable connectors.
    • Remove each of the ribbon cables from their connectors.
  7. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 7, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 7, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 7, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the eight 3 mm screws holding in the motherboard and the three 3 mm screws holding down the fan.
  8. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 8, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 8, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 8, image 3 de 3
    • Remove the motherboard and the fan by gently pulling them out of the assembly.
    • Using the Phillips #0 screwdriver, remove the three 3 mm screws holding down the daughterboard and gently pull it up and out of the assembly.
  9. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 9, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 9, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 9, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the eight 5 mm screws from the display brackets on either side.
  10. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 10, image 1 de 2 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 10, image 2 de 2
    • Remove the keyboard assembly by gently pulling it up.
  11. Acer Aspire R R5-471T-51UN Trackpad Replacement, Trackpad: étape 11, image 1 de 2 Acer Aspire R R5-471T-51UN Trackpad Replacement, Trackpad: étape 11, image 2 de 2
    • Use a spudger to flip up the locking tab of the trackpad ZIF connector and remove the ribbon cable from it.
    • Remove the two screws holding the trackpad to the frame with a Phillips #0 screwdriver.
  12. Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 12, image 1 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 12, image 2 de 3 Acer Aspire R R5-471T-51UN Trackpad Replacement: étape 12, image 3 de 3
    • Gently remove the trackpad from the keyboard assembly by pushing out the trackpad lightly from behind.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 380
