Aller au contenu principal
Acer Aspire R5-571T-59DC Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: étape 1, image 1 de 2 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: étape 1, image 2 de 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: étape 2, image 1 de 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: étape 2, image 2 de 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: étape 2, image 3 de 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Kelly Johnston
Membre depuis le 01/25/18
600 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S20-G2, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 membres
7 tutoriels rédigés
Un commentaire
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 5,094
