Aller au contenu principal
Acer Aspire R7 Speakers Replacement
Ce dont vous avez besoin
  1. Acer Aspire R7 Speakers Replacement, Cover: étape 1, image 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Speakers Replacement: étape 2, image 1 de 3 Acer Aspire R7 Speakers Replacement: étape 2, image 2 de 3 Acer Aspire R7 Speakers Replacement: étape 2, image 3 de 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Speakers Replacement: étape 3, image 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Speakers Replacement, Speakers: étape 4, image 1 de 2 Acer Aspire R7 Speakers Replacement, Speakers: étape 4, image 2 de 2
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Acer Aspire R7 Speakers Replacement: étape 5, image 1 de 2 Acer Aspire R7 Speakers Replacement: étape 5, image 2 de 2
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Acer Aspire R7 Speakers Replacement: étape 6, image 1 de 2 Acer Aspire R7 Speakers Replacement: étape 6, image 2 de 2
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Acer Aspire R7 Speakers Replacement: étape 7, image 1 de 2 Acer Aspire R7 Speakers Replacement: étape 7, image 2 de 2
    • Carefully lift the left-side speaker assembly away from the motherboard.
Andrew Rodiek
Membre depuis le 01/13/15
601 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 704
