Aller au contenu principal
Acer Aspire R7 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire R7 Wi-Fi Card Replacement, Cover: étape 1, image 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Wi-Fi Card Replacement: étape 2, image 1 de 3 Acer Aspire R7 Wi-Fi Card Replacement: étape 2, image 2 de 3 Acer Aspire R7 Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 2 Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 2 de 2
    • Locate the WiFi Card antenna wires
    • Remove both antenna wires from the WiFi card by prying upwards with the spudger tool
  5. Acer Aspire R7 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Remove the (1) 3.5mm #00 Phillips retaining screw
    • Once the screw is removed, the spring loaded hinge will tilt the WiFi card up
  6. Acer Aspire R7 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • With the retaining screw removed, pull the WiFi card out of the socket
2 autres ont terminé cette réparation.
Andrew Rodiek
Membre depuis le 01/13/15
601 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 membres
7 tutoriels rédigés
2 commentaires
The factory wi fi card is so weak. Is there a better wi fi card to buy and put in? 952-454-1659 Thank you
John - Réponse
This answer might be useful for others who still want to update their Wifi card in their R7-572.
I just replaced the original Broadcom BCM943228HMB on my R7-572 with an Intel 7260HMW CN: 08TF1D (Standard half-height mini PCI-e interface card ). I found it on ebay:https://www.ebay.ca/itm/4-0-Wireless-Min... (19 USD as of October 2018)
After the card is installed, run Intel Driver & Support Assistant and my driver where updated to the latest ones (for both the AC 7260 and the Bluetooth adapter). http://www.intel.com/content/www/us/en/s...
I am using Windows 8.1 on this laptop.
HTH
Michael Cantinotti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 37
Total : 3,982
