Aller au contenu principal
Acer Aspire S3 MS2346 Display Assembly Replacement
Ce dont vous avez besoin
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: étape 1, image 1 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: étape 1, image 2 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: étape 2, image 1 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: étape 2, image 2 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: étape 2, image 3 de 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: étape 3, image 1 de 2 Acer Aspire S3 MS2346 Display Assembly Replacement: étape 3, image 2 de 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: étape 4, image 1 de 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: étape 5, image 1 de 2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: étape 5, image 2 de 2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: étape 6, image 1 de 1
    • Unlatch the screen from the frame
3 autres ont terminé cette réparation.
Nikolas I Steckley
Membre depuis le 09/17/18
666 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G4, Hope Fall 2018
WSU-HOPE-F18S1G4
3 membres
6 tutoriels rédigés
3 commentaires
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Réponse
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 31
Total : 3,143
