Aller au contenu principal
Acer Aspire S3 MS2346 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: étape 1, image 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: étape 1, image 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: étape 2, image 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: étape 2, image 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: étape 2, image 3 de 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: étape 3, image 1 de 2 Acer Aspire S3 MS2346 Keyboard Replacement: étape 3, image 2 de 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: étape 4, image 1 de 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: étape 5, image 1 de 2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: étape 5, image 2 de 2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: étape 6, image 1 de 1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: étape 7, image 1 de 1
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: étape 8, image 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: étape 8, image 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: étape 8, image 3 de 3
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: étape 9, image 1 de 1
    • Gently lift the board exposing the keyboard assembly.
Nikolas I Steckley
Membre depuis le 09/17/18
666 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G4, Hope Fall 2018
WSU-HOPE-F18S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 1,487
