Aller au contenu principal
Acer Aspire S3-391-6046 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: étape 2, image 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: étape 2, image 2 de 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: étape 3, image 1 de 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: étape 4, image 1 de 1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: étape 5, image 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: étape 6, image 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: étape 6, image 2 de 2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: étape 7, image 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: étape 7, image 2 de 2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
2 autres ont terminé cette réparation.
Brian Rodriguez
Membre depuis le 09/18/18
530 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 13
Total : 708
