Aller au contenu principal
Acer Aspire S7-392-6484 LCD Replacement
Ce dont vous avez besoin
  1. Acer Aspire S7-392-6484 LCD Replacement, LCD: étape 1, image 1 de 2 Acer Aspire S7-392-6484 LCD Replacement, LCD: étape 1, image 2 de 2
    • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
    • Run a jimmy or similarly thin object around the edge of the screen.
    • Using a suction cup, lift up on the screen to separate it from the adhesive.
    • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
  2. Acer Aspire S7-392-6484 LCD Replacement: étape 2, image 1 de 2 Acer Aspire S7-392-6484 LCD Replacement: étape 2, image 2 de 2
    • Turn over the display to show the connectors underneath.
    • Disconnect the marked connectors to remove the display from the casing.
Nicholas Wise
Membre depuis le 02/14/18
754 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 1,720
