Aller au contenu principal
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 2, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 2, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 2, image 3 de 3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 3, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 3, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 3, image 3 de 3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 4, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 4, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 4, image 3 de 3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 5, image 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: étape 5, image 2 de 2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
9 autres ont terminé cette réparation.
Max Francois
Membre depuis le 09/28/16
684 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 7,391
