Aller au contenu principal
Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: étape 1, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 2, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 2, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 2, image 3 de 3
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 3, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 3, image 2 de 2
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 4, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 4, image 2 de 2
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 5, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 5, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 5, image 3 de 3
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 6, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 6, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 6, image 3 de 3
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 7, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 7, image 2 de 2
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 8, image 1 de 1
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 9, image 1 de 1
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 10, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: étape 10, image 2 de 2
    • Carefully remove the battery from the device by lifting it up.
4 autres ont terminé cette réparation.
Grecia Corrada
Membre depuis le 03/19/18
1 134 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 36
Total : 4,430
