Aller au contenu principal
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Ce dont vous avez besoin
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: étape 1, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: étape 1, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: étape 1, image 3 de 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 2, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 2, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 2, image 3 de 3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 3, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 3, image 2 de 2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 4, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 4, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 4, image 3 de 3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 5, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 5, image 2 de 2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 6, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 6, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 6, image 3 de 3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 7, image 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 7, image 2 de 2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 8, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 8, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 8, image 3 de 3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 9, image 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 9, image 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: étape 9, image 3 de 3
    • Pull the docking connector off of the screen section.
2 autres ont terminé cette réparation.
Grecia Corrada
Membre depuis le 03/19/18
1 134 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 membres
6 tutoriels rédigés
Un commentaire
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 2,948
