Aller au contenu principal
Acer Aspire TimelineX 4820T-6645 Wifi Module Replacement
Ce dont vous avez besoin
  1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Battery: étape 1, image 1 de 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 2, image 1 de 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 3, image 1 de 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 3, image 2 de 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: étape 4, image 1 de 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: étape 4, image 2 de 2
    • Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
    • Remove back cover from your laptop
  5. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 5, image 1 de 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 5, image 2 de 2
    • Disconnect the two antenna cables from the WLAN board as shown below
    • Black wire is terminal 1(left), white wire is terminal 2(right)
  6. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 6, image 1 de 1
    • Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
  7. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: étape 7, image 1 de 1
    • Detach and remove the WLAN board from the WLAN socket
Dylan Bryda
Membre depuis le 03/26/19
109 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G3, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S4-G3, Valliere Spring 2019
UMASSD-VALLIERE-S19S4G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 222
