Aller au contenu principal
Acer Aspire TimelineX 4820T-6645 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire TimelineX 4820T-6645 RAM Replacement, Battery: étape 1, image 1 de 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 2, image 1 de 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 3, image 1 de 2 Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 3, image 2 de 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: étape 4, image 1 de 2 Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: étape 4, image 2 de 2
    • Flip the laptop over and locate the hard drive cover. This is a L shaped plastic cover and has 5 PH#1 8mm screws located around the outside edge. The screw locations are denoted by red circles in the figure.
    • Remove those five screws and then remove the cover.
  5. Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 5, image 1 de 3 Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 5, image 2 de 3 Acer Aspire TimelineX 4820T-6645 RAM Replacement: étape 5, image 3 de 3
    • On either side of the RAM module, there will be two metal tabs. Slide both tabs away from the memory module and the RAM module will pop loose.
    • The location of the tabs are shown by two red circles. Once these tabs are pulled to the side the RAM will pop up. Pulling straight back on the module will remove it.
    • Be careful, these metal tabs may break if you apply too much force to them.
Michael Kilmartin
Membre depuis le 03/26/19
331 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G3, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S4-G3, Valliere Spring 2019
UMASSD-VALLIERE-S19S4G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 280
