Introduction
This guide provides simple steps to replace the optical drive on the Acer Aspire TimelineX 4830T-6682 using minimal tools that can be acquired locally, or through iFixit. Please make sure and follow the prerequisite procedures.
Ce dont vous avez besoin
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
After the panel has been removed, locate the RAM. It should be on the lower right.
There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
Outil utilisé dans cette étape :Tweezers$3.99
Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
The battery will be on the side closest to the screen.
Gently lift it out. It will still be attached by white, red, and black wires.
Elevate the optical drive to get a good grip, then slide the drive horizontally away from the laptop, disconnecting it from the motherboard
