Aller au contenu principal
Acer Aspire V3-551-8887 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire V3-551-8887 Keyboard Replacement, Back Panel: étape 1, image 1 de 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Keyboard Replacement: étape 2, image 1 de 2 Acer Aspire V3-551-8887 Keyboard Replacement: étape 2, image 2 de 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Keyboard Replacement, USB Ports: étape 3, image 1 de 1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Keyboard Replacement: étape 4, image 1 de 2 Acer Aspire V3-551-8887 Keyboard Replacement: étape 4, image 2 de 2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Keyboard Replacement: étape 6, image 1 de 2 Acer Aspire V3-551-8887 Keyboard Replacement: étape 6, image 2 de 2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Keyboard Replacement: étape 7, image 1 de 2 Acer Aspire V3-551-8887 Keyboard Replacement: étape 7, image 2 de 2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Keyboard Replacement: étape 8, image 1 de 1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Keyboard Replacement: étape 9, image 1 de 1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Keyboard Replacement, Keyboard: étape 10, image 1 de 1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Keyboard Replacement: étape 11, image 1 de 2 Acer Aspire V3-551-8887 Keyboard Replacement: étape 11, image 2 de 2
    • Use a spudger to gently lift the keyboard.
3 autres ont terminé cette réparation.
Alexander Lazar
Membre depuis le 04/22/14
357 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 31
Total : 6,643
