Aller au contenu principal
Acer Aspire V3-771G Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: étape 2, image 1 de 3 Acer Aspire V3-771G Hard Drive Replacement: étape 2, image 2 de 3 Acer Aspire V3-771G Hard Drive Replacement: étape 2, image 3 de 3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: étape 3, image 1 de 2 Acer Aspire V3-771G Hard Drive Replacement: étape 3, image 2 de 2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: étape 4, image 1 de 2 Acer Aspire V3-771G Hard Drive Replacement: étape 4, image 2 de 2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: étape 5, image 1 de 3 Acer Aspire V3-771G Hard Drive Replacement: étape 5, image 2 de 3 Acer Aspire V3-771G Hard Drive Replacement: étape 5, image 3 de 3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
9 autres ont terminé cette réparation.
David Walker
Membre depuis le 10/11/14
341 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-36, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 membre
1 tutoriel rédigé
Un commentaire
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 35
Total : 13,654
