Aller au contenu principal
Acer Aspire V5-131-2629 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-131-2629 RAM Replacement, Battery: étape 1, image 1 de 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 RAM Replacement: étape 2, image 1 de 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 RAM Replacement: étape 3, image 1 de 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 RAM Replacement: étape 4, image 1 de 2 Acer Aspire V5-131-2629 RAM Replacement: étape 4, image 2 de 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 RAM Replacement, Cover: étape 5, image 1 de 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 RAM Replacement: étape 6, image 1 de 2 Acer Aspire V5-131-2629 RAM Replacement: étape 6, image 2 de 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 RAM Replacement, RAM: étape 7, image 1 de 1
    • Using your finger, press the small tab on each side of the memory card.
    • The memory card will eject at a 45 degree angle.
  8. Acer Aspire V5-131-2629 RAM Replacement: étape 8, image 1 de 1
    • Pull the memory cards out from the laptop.
Nicholas Vassiliadis
Membre depuis le 10/25/19
85 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 571
