Aller au contenu principal
Acer Aspire V5-571 Loudspeakers Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: étape 1, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: étape 1, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Loudspeakers Replacement: étape 2, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 2, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 2, image 3 de 3
  3. Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: étape 3, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: étape 3, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: étape 3, image 3 de 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: étape 4, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: étape 4, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: étape 4, image 3 de 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Loudspeakers Replacement: étape 5, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 5, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 5, image 3 de 3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): étape 6, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): étape 6, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): étape 6, image 3 de 3
  7. Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: étape 7, image 1 de 2 Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: étape 7, image 2 de 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: étape 8, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: étape 8, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: étape 8, image 3 de 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Loudspeakers Replacement: étape 9, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 9, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 9, image 3 de 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Loudspeakers Replacement: étape 10, image 1 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 10, image 2 de 3 Acer Aspire V5-571 Loudspeakers Replacement: étape 10, image 3 de 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: étape 11, image 1 de 2 Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: étape 11, image 2 de 2
    • There are two Loudspeakers. Each of them is held by two Phillips screws.
    • Did you do it successfully?
ZFix
Membre depuis le 12/09/13
191 647 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 500 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 1,653
