Aller au contenu principal
Acer Aspire V5-571 Upper Cover Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: étape 1, image 1 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: étape 1, image 2 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: étape 2, image 1 de 3 Acer Aspire V5-571 Upper  Cover Replacement: étape 2, image 2 de 3 Acer Aspire V5-571 Upper  Cover Replacement: étape 2, image 3 de 3
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: étape 3, image 1 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: étape 3, image 2 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: étape 3, image 3 de 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: étape 4, image 1 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: étape 4, image 2 de 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: étape 4, image 3 de 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: étape 5, image 1 de 3 Acer Aspire V5-571 Upper  Cover Replacement: étape 5, image 2 de 3 Acer Aspire V5-571 Upper  Cover Replacement: étape 5, image 3 de 3
    • Carefully separate the upper cover and remove it.
ZFix
Membre depuis le 12/09/13
191 647 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 500 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 3,009
