Aller au contenu principal
Acer E5-571-54FL Optical Drive Replacement
Ce dont vous avez besoin
  1. Acer E5-571-54FL Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Optical Drive Replacement: étape 2, image 1 de 2 Acer E5-571-54FL Optical Drive Replacement: étape 2, image 2 de 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Optical Drive Replacement: étape 3, image 1 de 2 Acer E5-571-54FL Optical Drive Replacement: étape 3, image 2 de 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
  5. Acer E5-571-54FL Optical Drive Replacement: étape 5, image 1 de 3 Acer E5-571-54FL Optical Drive Replacement: étape 5, image 2 de 3 Acer E5-571-54FL Optical Drive Replacement: étape 5, image 3 de 3
    • Slide out the old optical drive and remove it from the device.
Jennifer Hancock
Membre depuis le 09/19/19
325 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 13
Total : 439
