Aller au contenu principal
Acer Iconia W3-810 Battery Replacement
Ce dont vous avez besoin
  1. Acer Iconia W3-810 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Battery Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Battery Replacement, Battery: étape 3, image 1 de 1
    • Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
  4. Acer Iconia W3-810 Battery Replacement: étape 4, image 1 de 1
    • Move the ribbon cord in order to disconnect the rainbow cord from the battery.
    • Take extra care to not rip the ribbon cord.
  5. Acer Iconia W3-810 Battery Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
  6. Acer Iconia W3-810 Battery Replacement: étape 6, image 1 de 1
    • Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
    • Do not pull the ribbon cord too hard or near the opposite end.
  7. Acer Iconia W3-810 Battery Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
  8. Acer Iconia W3-810 Battery Replacement: étape 8, image 1 de 2 Acer Iconia W3-810 Battery Replacement: étape 8, image 2 de 2
    • Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
  9. Acer Iconia W3-810 Battery Replacement: étape 9, image 1 de 1
    • Remove battery pack
3 autres ont terminé cette réparation.
Adam Fierce
Membre depuis le 09/15/16
418 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 18-4, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 membres
6 tutoriels rédigés
Un commentaire
Good show .i like the simple steps
alibar1 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 37
Total : 4,169
