Aller au contenu principal
Acer Nitro 5 AN515-55-56GN HDD Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: étape 1, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: étape 1, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: étape 1, image 3 de 3
    • Turn off the laptop and unplug it from the charging cord.
    • Flip the laptop over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove ten 9 mm screws.
  2. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 2, image 3 de 3
    • Use your fingers or an opening tool to remove the back case by separating it at the seam.
    • Work your way gently around the perimeter to undo the clips.
    • Remove the back case.
  3. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 3, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 3, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 3, image 3 de 3
    • Unplug the battery cable from the connector attaching the battery to the motherboard.
    • Make sure that the laptop battery is unplugged or remove the battery before installing the HDD.
  4. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 4, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 4, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 4, image 3 de 3
    • Use the Phillips #0 screwdriver to remove four 3 mm screws from the hard drive bracket.
    • Remove the bracket from the device.
  5. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 5, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 5, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 5, image 3 de 3
    • Place the HDD 1TB in the bracket.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws that hold the HDD in the bracket.
    • The 2 mm screws are included with the new HDD.
  6. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 6, image 1 de 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 6, image 2 de 2
    • Attach the SATA connector to the HDD.
  7. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 7, image 1 de 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 7, image 2 de 2
    • Slide the HDD into the socket on the motherboard.
    • Replace the four 3 mm screws using the Phillips #0 screwdriver.
  8. Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 8, image 1 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 8, image 2 de 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: étape 8, image 3 de 3
    • Slide the hard drive cable into the connector on the motherboard.
    • Flip the black lock down to secure the cable.
That is all step-to-step on how to Install the new HDD to the laptop Acer Nitro 5 (AN515-55-56GN)
5 autres ont terminé cette réparation.
Duy Nguyen
Membre depuis le 09/16/21
253 Réputation
1 tutoriel rédigé
Équipe
York University, Team M-17, Allen Summer 2022 Membre de l'équipe York University, Team M-17, Allen Summer 2022
YORK-ALLEN-SU22SMG17
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 49
30 derniers jours : 199
Total : 5,054
