Aller au contenu principal
Altec Lansing OVO Bluetooth Speaker Disassembly
Ce dont vous avez besoin
  1. Altec Lansing OVO Bluetooth Speaker Disassembly, Altec Lansing OVO Bluetooth Speaker Disassembly: étape 1, image 1 de 1
    • This is the unit that we are going to disassemble.
  2. Altec Lansing OVO Bluetooth Speaker Disassembly: étape 2, image 1 de 1
    • Screws approximate location behind the front cover.
  3. Altec Lansing OVO Bluetooth Speaker Disassembly: étape 3, image 1 de 1
    • Use a pick to gently pull the cover. There are no fragile parts. The cover is made of metal and covered with a type of mesh.
  4. Altec Lansing OVO Bluetooth Speaker Disassembly: étape 4, image 1 de 3 Altec Lansing OVO Bluetooth Speaker Disassembly: étape 4, image 2 de 3 Altec Lansing OVO Bluetooth Speaker Disassembly: étape 4, image 3 de 3
    • Once the front cover is removed gently lift the thin protection layer in order to find the holes where the screws are located. In order to find the two middle screws you will have to make two small incisions as shown in the picture.
  5. Altec Lansing OVO Bluetooth Speaker Disassembly: étape 5, image 1 de 2 Altec Lansing OVO Bluetooth Speaker Disassembly: étape 5, image 2 de 2
    • After you remove the 13 screws, put your finger in the woofer hole on the back of the speaker. Pull gently outwards to make sure you don't break the flat cable that connects the back to the main board. And that's it! Now you have full access to all the inner parts of your speaker.
Merci à ces traducteurs :
pt en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Nuno
Membre depuis le 03/02/22
181 Réputation
1 tutoriel rédigé
Un commentaire
What is the spec on the battery in this unit (Altec Lansing OVO AL-BT42S)?
Hugo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 42
Total : 788
