Aller au contenu principal
Amazon Kindle DX LCD Replacement
Ce dont vous avez besoin
  1. Amazon Kindle DX LCD Replacement, Liquid Crystal Display (LCD): étape 1, image 1 de 1
    • Take your Kindle and place it screen side down in order to open it from the back. Use the opening tool from the ifixit tool kit and insert it between the metal casing and plastic top piece.
  2. Amazon Kindle DX LCD Replacement: étape 2, image 1 de 1
    • Once enough pressure is applied the small piece will pop open.
  3. Amazon Kindle DX LCD Replacement: étape 3, image 1 de 1
    • Remove the plastic piece.
  4. Amazon Kindle DX LCD Replacement: étape 4, image 1 de 2 Amazon Kindle DX LCD Replacement: étape 4, image 2 de 2
    • Once the small plastic piece is removed you will need to locate two 40mm screws on both corners of the remaining casing. Use the PH000 Philips Head Screwdriver from the tool kit to remove both screws.
  5. Amazon Kindle DX LCD Replacement: étape 5, image 1 de 1
    • Use the opening tool again to take the off the bigger metal piece.
  6. Amazon Kindle DX LCD Replacement: étape 6, image 1 de 1
    • Once the piece removed, locate the battery.
  7. Amazon Kindle DX LCD Replacement: étape 7, image 1 de 2 Amazon Kindle DX LCD Replacement: étape 7, image 2 de 2
    • Locate the two 30mm screws securing the battery on the bottom of the Kindle DX. Use the PH00 Philips head screw driver from the tool kit to remove both screws.
  8. Amazon Kindle DX LCD Replacement: étape 8, image 1 de 2 Amazon Kindle DX LCD Replacement: étape 8, image 2 de 2
    • Take the battery off once the screws have been removed.
  9. Amazon Kindle DX LCD Replacement: étape 9, image 1 de 2 Amazon Kindle DX LCD Replacement: étape 9, image 2 de 2
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as shown in the picture.
  10. Amazon Kindle DX LCD Replacement: étape 10, image 1 de 2 Amazon Kindle DX LCD Replacement: étape 10, image 2 de 2
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as demonstrated in the picture.
  11. Amazon Kindle DX LCD Replacement: étape 11, image 1 de 1
    • Remove the black case to reveal the mother board.
  12. Amazon Kindle DX LCD Replacement: étape 12, image 1 de 1
    • Remove the motherboard from the display assembly.
Lori White
Membre depuis le 09/28/16
557 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 membres
8 tutoriels rédigés
3 commentaires
Guide is incomplete :(
Robert Rogers - Réponse
I can follow and understand up to step 11.
Steps 12 and 13 loose me, why would one need to remove the metal protection lid / shield? There does not seem to be any screws covered by the lids that need to be removed.
one would need to unclip the screen from the motherboard the lead off board from the wireless card to aerial and unscrew the remaining motherboard screws at least before you could remove the motherboard to access the screen to replace it.
Terry Mummery - Réponse
Guide is useless and should be removed or replaced.
golan.benoni - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 3,321
