Introduction
The Zephyrus G14 has two RAM slots. The first slot of Ram is soldered to the board. The second slot of Ram is accessible by taking off the backplate of the laptop. It is necessary to have these two slots of Ram filled can take advantage of Dual-Channel Memory. Dual-Channel Memory allows the Ram to function at its full potential in gaming and productivity applications. To take advantage of Dual-Channel Memory, ensure that the replacement stick is the same size and speed as the soldered stick.
Ce dont vous avez besoin
Remove the screws on the back. Unscrew them with a Phillips #0 screwdriver.
Remove the three (2x4.5mm) screws from the front of the laptop.
Remove the ten (2x9mm) screws from the middle and back of the laptop.
Unscrew the (2x6mm) captive screw in the bottom right without removing it.
6 autres ont terminé cette réparation.
Un commentaire
Something that might be helpful for this guide is including the RAM specifications needed for an upgrade if people are looking for information on what to buy.
Otherwise, great guide!
