Aller au contenu principal
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 2, image 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 2, image 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 2, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 3, image 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 3, image 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 3, image 3 de 3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 4, image 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 4, image 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 4, image 3 de 3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 5, image 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 5, image 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 5, image 3 de 3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 6, image 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 6, image 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: étape 6, image 3 de 3
    • Carefully remove the battery using a plastic opening tool.
Vivek Rana
Membre depuis le 09/11/21
169 Réputation
1 tutoriel rédigé
Équipe
York University, Team E-23, Melo-Thaiss Fall 2021 Membre de l'équipe York University, Team E-23, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG23
1 membre
1 tutoriel rédigé
Un commentaire
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 51
Total : 2,173
