Aller au contenu principal
Beaded Bracelet Clasp Replacement
Ce dont vous avez besoin
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: étape 1, image 1 de 1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: étape 2, image 1 de 1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: étape 3, image 1 de 1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: étape 4, image 1 de 2 Beaded Bracelet Clasp Replacement: étape 4, image 2 de 2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: étape 5, image 1 de 1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: étape 6, image 1 de 1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: étape 7, image 1 de 1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: étape 8, image 1 de 1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: étape 9, image 1 de 2 Beaded Bracelet Clasp Replacement: étape 9, image 2 de 2
2 autres ont terminé cette réparation.
Kelly
Membre depuis le 03/22/16
182 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-17, Lauer Spring 2016 Membre de l'équipe Michigan Tech, Team 1-17, Lauer Spring 2016
MTU-LAUER-S16S1G17
1 membre
1 tutoriel rédigé
2 commentaires
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 35
Total : 2,417
