Ce dont vous avez besoin
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Outil utilisé dans cette étape :Tweezers$4.99
Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
Remove the faceplate by lifting the plate upward.
Using a plastic pry tool, lift and remove the three tabs securing the trackpad restrainer to the trackpad.
2 autres ont terminé cette réparation.
