Aller au contenu principal
Bottom Cover
Ce dont vous avez besoin
  1. Bottom Cover, Battery: étape 1, image 1 de 1
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Bottom Cover: étape 2, image 1 de 1
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Bottom Cover: étape 3, image 1 de 1
    • Slide the middle lock to the right and the battery will pop up.
  4. Bottom Cover: étape 4, image 1 de 1
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Bottom Cover, Bottom Cover: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    J'achète
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws and the bottom panel should pop off.
  6. Bottom Cover: étape 6, image 1 de 1
    • After that you are in and now can change most of the components, which we also have tutorials for.
Regome
Membre depuis le 01/20/23
767 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 7
Total : 74
