Aller au contenu principal
Buick Key Fob Battery Replacement
Ce dont vous avez besoin
  1. Buick Key Fob Battery Replacement, Remove the Inner Key: étape 1, image 1 de 1
    • Push the chrome button on the back of the key fob to release the inner key
  2. Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: étape 2, image 1 de 2 Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: étape 2, image 2 de 2
    • Using an opening tool/pick helps avoid damage, however you can also use the inner key to pry the two shells apart
    • If using the inner key to pry them apart, just reinsert the tip of the key into fob and gently twist
  3. Buick Key Fob Battery Replacement, Remove Old Battery: étape 3, image 1 de 1
    • Slide a tool underneath the old battery to pop it out, the replacement battery goes in face down toward the bottom shell
Jim
Membre depuis le 06/17/23
331 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 36
Total : 697
