Aller au contenu principal
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
Ce dont vous avez besoin
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: étape 1, image 1 de 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: étape 1, image 2 de 2
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: étape 2, image 1 de 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: étape 2, image 2 de 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: étape 2, image 3 de 3
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: étape 3, image 1 de 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: étape 3, image 2 de 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: étape 3, image 3 de 3
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: étape 4, image 1 de 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: étape 4, image 2 de 2
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: étape 5, image 1 de 1
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
Ligne d'arrivée
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
es en
100%
WhoDat? nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jonatan M
Membre depuis le 03/17/18
530 Réputation
2 tutoriels rédigés
Un commentaire
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 136
30 derniers jours : 295
Total : 7,300
