Aller au contenu principal
Canon EOS Rebel T2i Top Casing Replacement
Ce dont vous avez besoin
  1. Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: étape 1, image 1 de 2 Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: étape 1, image 2 de 2
    • Remove the battery using the 00 screwdriver.
    • Remove the neck strap
    • Remove the plastic casing around the viewing lens
  2. Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: étape 2, image 1 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: étape 2, image 2 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: étape 2, image 3 de 3
    • Remove these screws.
  3. Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: étape 3, image 1 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: étape 3, image 2 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: étape 3, image 3 de 3
  4. Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: étape 4, image 1 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: étape 4, image 2 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: étape 4, image 3 de 3
    • Remove the screws below the view finder.
    • Remove the screw of the focus wheel right from the view finder using the 000 screw driver
    • Remove the top screws.
    • Using your fingers, remove the left wire connecting the microphone.
  5. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: étape 5, image 1 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: étape 5, image 2 de 3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: étape 5, image 3 de 3
    • Use your fingers to complete the following steps. Remove the black wire beneath the power switch.
    • Remove the wire on the left side shown.
    • Remove the two ribbon wires on the right side.
  6. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: étape 6, image 1 de 2 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: étape 6, image 2 de 2
    • Remove the circled wires on the front with your fingers.
    • Remove the top casing and replace it with a new one. This casing should include a new power switch. Reconnect all wires and replace the back and front casings.
This guide demonstrates how to replace the power button. To reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Stefan Seitler
Membre depuis le 10/27/14
470 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-4, Duarte Fall 2014
UMASSD-DUARTE-F14S1G4
3 membres
4 tutoriels rédigés
Un commentaire
The top cover assembly part number for the Rebel T2i/EOS 550D is CG2-2756-010.
ogminlo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 28
Total : 2,788
