Aller au contenu principal
Canon EOS Rebel T2i Tripod Mount Replacement
Ce dont vous avez besoin
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: étape 1, image 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: étape 1, image 2 de 2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: étape 2, image 1 de 1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: étape 3, image 1 de 1
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: étape 4, image 1 de 1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: étape 5, image 1 de 1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: étape 6, image 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement: étape 6, image 2 de 2
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: étape 7, image 1 de 1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: étape 8, image 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement: étape 8, image 2 de 2
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
Jacob Jaskolka
Membre depuis le 03/30/15
745 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Shastany Spring 2015 Membre de l'équipe UMass Dartmouth, Team 1-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 1,666
