Aller au contenu principal
Craig CMP801 Battery Replacement
Ce dont vous avez besoin
  1. Craig CMP801 Battery Replacement, Back Cover: étape 1, image 1 de 2 Craig CMP801 Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: étape 2, image 1 de 2 Craig CMP801 Battery Replacement: étape 2, image 2 de 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: étape 3, image 1 de 2 Craig CMP801 Battery Replacement: étape 3, image 2 de 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: étape 4, image 1 de 3 Craig CMP801 Battery Replacement, Battery: étape 4, image 2 de 3 Craig CMP801 Battery Replacement, Battery: étape 4, image 3 de 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: étape 5, image 1 de 3 Craig CMP801 Battery Replacement: étape 5, image 2 de 3 Craig CMP801 Battery Replacement: étape 5, image 3 de 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Duyen
Membre depuis le 09/25/17
281 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Where do I find a battery cmp749 ???
kourriclay929 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 1,018
