Aller au contenu principal
Creality Ender 3 Bracket Plate of Y-Axis Motor Replacement
Ce dont vous avez besoin
  1. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement, Bracket Plate of Y-Axis Motor: étape 1, image 1 de 1
    • Place the bed plate in the middle of your Ender 3. Do this manually by gently pushing it to the middle.
  2. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 2, image 1 de 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 2, image 2 de 2
    • Or alternatively, place the bed in the center by turning your Ender 3 on.
  3. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 3, image 1 de 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 3, image 2 de 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 3, image 3 de 3
    • Turn on the printer, and click the button to the screen shown in the photo.
    • Rotate the button clockwise to "Prepare".
    • Rotate the button clockwise to AutoHome. This should set your bedplate to 0 on both X & Y axes.
  4. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 4, image 1 de 1
    • Unplug the wire that is connected to the Y motor.
  5. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 5, image 1 de 1
    • Remove the two M4*20 screws from the back end of the Y-axis bar using an 8 mm Allen Wrench. The side of the display should be facing you.
  6. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 6, image 1 de 1
    • Remove the four M3*6 screws that are attaching the motor to the Y-axis motor using an 8 mm Allen Wrench.
  7. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 7, image 1 de 1
    • Buy a new bracket with the same brand (depending on the severity of the bend of the bracket) or straighten the metal on your own.
  8. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 8, image 1 de 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 8, image 2 de 2
    • If you choose to fix it on your own, slip the bracket in between a workshop bench clamp. Apply enough pressure between two thick blocks of metal to straighten it.
    • Use vise-grips to aid in stabilizing the metal as you force the metal to straighten.
  9. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 9, image 1 de 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: étape 9, image 2 de 2
    • Repeat, Steps 6-11 in reverse to put the bracet back on the Y motor and back on the Ender 3.
    • Turn on Ender 3 to see if you did it correctly. Try to also print something too!
Isabella Bianca Reano
Membre depuis le 04/18/21
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 53
Total : 1,830
