Introduction
Unless you have a starter pack with a pre-made Bootable SD Card, you'd need to create one for your Raspberry Pi.
In this guide I will walk you through the creation of your Bootable SD Card (This card will contain your Raspberry Pi's Operating System and will act as your device's storage).
Ce dont vous avez besoin
To create our Bootable SD Card we will need the Official Raspberry Pi Imager software. This software is completely free, and can be downloaded here.
Once your download has been completed, open the Pi Imager program, and insert your SD Card into your computer. The Imager software should automatically detect your SD Card, and will begin to format the card.
Once your SD Card has been targeted, you'll need to select the Operating System that you would like loaded onto your SD Card.
Once your OS has been selected, select your inserted SD card.
Once you have your SD Card selected, click on the Write button. If prompted enter the password to your computer.
When the installation is complete, Imager will prompt you to remove your SD Card.
To begin using your Bootable SD Card, simply insert the card into your Raspberry Pi, and power on your device.
It is possible that at the moment you begin to WRITE the OS to your SD Card an alert may appear warning that the card is write protected. This happens when the switch on the left side of the SD is in protection mode.
You can solve this by ejecting the SD Card and move the lever to the side opposite, then repeat the OS selection operation. and of the SD Card.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
