Aller au contenu principal
Daewoo DWC LDC1412S Water pump replacement Replacement
Ce dont vous avez besoin
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: étape 1, image 1 de 1
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 2, image 1 de 2 Daewoo DWC LDC1412S Water pump replacement Replacement: étape 2, image 2 de 2
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 3, image 1 de 1
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 4, image 1 de 2 Daewoo DWC LDC1412S Water pump replacement Replacement: étape 4, image 2 de 2
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 5, image 1 de 1
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 6, image 1 de 1
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: étape 7, image 1 de 1
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
2 autres ont terminé cette réparation.
hellotheworld
Membre depuis le 12/06/14
191 Réputation
1 tutoriel rédigé
Un commentaire
Thanks, this saved me heaps of money!!!
Brendan Innes - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 26
30 derniers jours : 77
Total : 3,664
