Aller au contenu principal
Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation)
Ce dont vous avez besoin
  1. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: étape 1, image 1 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: étape 1, image 2 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disassembly: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • You will need to leave your Kindle powered on but in sleep mode.
    • If it has run out of power, you may want to plug it in first to ensure that the display is still intact and not cracked.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • You may need plastic cards in between the bezel and rear cover if the former keeps sticking back down while you attempt to pry it up.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 2, image 1 de 2 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 2, image 2 de 2
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  3. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 3, image 1 de 1
    • Gently lift the mid-frame out of the case with your hands.
  4. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: étape 4, image 1 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: étape 4, image 2 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation), Disconnecting the Frontlight: étape 4, image 3 de 3
    • Now comes the hard part.
    • Your Kindle may not respond to the power button, and disconnecting the frontlight at this point will leave it in that unusable state.
    • Tap on or bring a magnet close to the hall effect sensor.
    • When the frontlight lights up, immediately unplug its connector.
    • If your Kindle remains awake for more than 3 seconds, you may now put it back to sleep by pressing the power button.
    • If not, you may have to repeat this step.
  5. Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 5, image 1 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 5, image 2 de 3 Disabling the Cover Sensor on Kindle Paperwhite 3 (7th Generation): étape 5, image 3 de 3
    • You will then need to cover pins 2 and 4 of the front light connector.
    • Cut a small piece of electrical tape that is thin enough to cover both pins, and apply it.
    • Reconnect the frontlight.
    • Be careful to not block pin 6 and/or any other pins, as it may result in the frontlight not receiving power and/or the device re-entering the closed cover state.
To reassemble your device, follow steps 1-3 in reverse order.
Kevin Bhasi
Membre depuis le 12/26/14
1 262 Réputation
9 tutoriels rédigés
3 commentaires
Brilliant! I just went through the process of disconnecting my hall sensor harness to fix an intermittent wake/lock issue. It worked, but i didn’t realize I’d nerfed the backlights until after getting it all reassembled. Thankfully found this guide and it worked perfectly.
Daniel Swick - Réponse
Cover sensor was malfunctioning after a battery replacement so I followed your guide and it worked wonderfully! Hope to get another 8 years from this thing instead of dropping it in a landfill! Thanks
Andrew McDonnell - Réponse
Very clever! Thank you. In the event, changing the battery on my 7th generation Kindle Paperwhite seems to have fixed the problem with the cover sensor. That triggered a hard reset, so it might be worth trying that before continuing with this mod.
Charles Butcher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 69
Total : 3,004
