Aller au contenu principal
Disassembling Sony Clie PEG-NR70 The Case
Ce dont vous avez besoin
  1. Disassembling Sony Clie PEG-NR70 The Case, The Case: étape 1, image 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Disassembling Sony Clie PEG-NR70 The Case: étape 2, image 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Disassembling Sony Clie PEG-NR70 The Case: étape 3, image 1 de 2 Disassembling Sony Clie PEG-NR70 The Case: étape 3, image 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
Daniel Soski
Membre depuis le 04/18/13
57 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-11, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 8
Total : 673
