Aller au contenu principal
E-Cigarette Vaporizer Coil Replacement
Ce dont vous avez besoin
  1. E-Cigarette Vaporizer Coil Replacement, Coil: étape 1, image 1 de 2 E-Cigarette Vaporizer Coil Replacement, Coil: étape 1, image 2 de 2
    • Pull up to remove the top cap from the IPV Mini II.
    • The unit may have hot surfaces.
    • Allow components to cool before starting.
  2. E-Cigarette Vaporizer Coil Replacement: étape 2, image 1 de 1
    • Using a Phillips head screwdriver, turn counter clockwise to loosen the positive and negative screws.
    • Be sure that the IPV Mini II is powered off before proceeding.
  3. E-Cigarette Vaporizer Coil Replacement: étape 3, image 1 de 1
    • Gently remove the burnt coil from the positive and negative screws.
  4. E-Cigarette Vaporizer Coil Replacement: étape 4, image 1 de 1
    • Place the new coil into the holes underneath the positive and negative screws.
  5. E-Cigarette Vaporizer Coil Replacement: étape 5, image 1 de 1
    • Using a Phillips screwdriver, gently turn clockwise to tighten down the positive and negative screws onto the coil.
  6. E-Cigarette Vaporizer Coil Replacement: étape 6, image 1 de 2 E-Cigarette Vaporizer Coil Replacement: étape 6, image 2 de 2
    • Replace the top cap onto the IPV Mini II.
To reverse the process, simply follow the instructions in reverse.
For more information visit https://bevapehappy.com/
12 autres ont terminé cette réparation.
rzgraves
Membre depuis le 07/16/15
624 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 3-4, Rauch SU 2015 Membre de l'équipe Texas Tech, Team 3-4, Rauch SU 2015
TTU-RAUCH-SU15S3G4
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 45
Total : 5,256
