Aller au contenu principal
Eyelash Extensions Replacement
Ce dont vous avez besoin
  1. Eyelash Extensions Replacement, Eyelash Extensions: étape 1, image 1 de 1
    • Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
  2. Eyelash Extensions Replacement: étape 2, image 1 de 1
    • Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
  3. Eyelash Extensions Replacement: étape 3, image 1 de 1
    • Make sure that the client feels comfortable with the tape on with their eyes closed.
  4. Eyelash Extensions Replacement: étape 4, image 1 de 1
    • Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
  5. Eyelash Extensions Replacement: étape 5, image 1 de 2 Eyelash Extensions Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove all the grown-out lashes using the banana peel method.
    • Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
    • Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
  6. Eyelash Extensions Replacement: étape 6, image 1 de 1
    • Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
  7. Eyelash Extensions Replacement: étape 7, image 1 de 3 Eyelash Extensions Replacement: étape 7, image 2 de 3 Eyelash Extensions Replacement: étape 7, image 3 de 3
    • Put a drop or two of the eyelash primer on the micro swabs.
    • Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
  8. Eyelash Extensions Replacement: étape 8, image 1 de 1
    • Let it air dry or use a fan for a faster dry time.
  9. Eyelash Extensions Replacement: étape 9, image 1 de 1
    • Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
  10. Eyelash Extensions Replacement: étape 10, image 1 de 2 Eyelash Extensions Replacement: étape 10, image 2 de 2
    • Repeat Step 9 for both eyes until you are completely satisfied with your work.
  11. Eyelash Extensions Replacement: étape 11, image 1 de 1
    • Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
  12. Eyelash Extensions Replacement: étape 12, image 1 de 1
    • Use a fan for 5-10 minutes to make sure that the adhesive is cured.
  13. Eyelash Extensions Replacement: étape 13, image 1 de 1
    • Gently remove the tape from under each eye.
Ligne d'arrivée
April Pantaleon
Membre depuis le 09/20/20
349 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G20, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G20, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G20
1 membre
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 336
