Aller au contenu principal
Felco Gartenschere - Pruners Disassembly
Ce dont vous avez besoin
  1. Felco Gartenschere - Pruners Disassembly, Various types available: étape 1, image 1 de 1
    • There are several types - e.g. also for left-handers, here a Felco Nr 4 is shown.
  2. Felco Gartenschere - Pruners Disassembly, Release mother: étape 2, image 1 de 1
    • First, the upper nut SW 13 is released, then the scissors is turned over.
    • The spring can be easily removed.
  3. Felco Gartenschere - Pruners Disassembly, Release screw from below: étape 3, image 1 de 1
    • Now the hinge screw can be unscrewed. Here SW 14 is used Next to it lies the spring and the lock nut.
    • Now the scissors can be completely disassembled.
    • The blade is pinned with three bolts in the handle half and usually dissolves easily.
  4. Felco Gartenschere - Pruners Disassembly, The items: étape 4, image 1 de 1
    • The scissors are disassembled. We see the pivot nut, the hinge screw, the spring, the two handles and the blade.
    • The blade is ground on one side. Sharpen the beveled edge with about 15 degrees, only deburr the straight edge with a maximum of 5 degrees.
    • The parts should be free from rust and freshly oiled or greased.
Repeat the steps in order to reassemble your device.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
206 702 Réputation
255 tutoriels rédigés
Équipe
Repair is War on Entropy Membre de l'équipe Repair is War on Entropy
Community
25 membres
1 164 tutoriels rédigés
2 commentaires
Does the fixed bolt need Locktight or thread locker applied to its thread to stop it coming loose in operation?
Nicholas Little - Réponse
I did not use a thread locker and ist works until today.
VauWeh -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 31
Total : 2,200
