Aller au contenu principal
Fender Jazz Bass Strings Replacement
Ce dont vous avez besoin
  1. Fender Jazz Bass Strings Replacement, Strings: étape 1, image 1 de 1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: étape 2, image 1 de 1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: étape 3, image 1 de 2 Fender Jazz Bass Strings Replacement: étape 3, image 2 de 2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: étape 4, image 1 de 2 Fender Jazz Bass Strings Replacement: étape 4, image 2 de 2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: étape 5, image 1 de 1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: étape 6, image 1 de 2 Fender Jazz Bass Strings Replacement: étape 6, image 2 de 2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
Ligne d'arrivée
Matthew Caldera
Membre depuis le 01/24/22
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-1, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 1-1, Briggs Spring 2022
CSULA-BRIGGS-S22S1G1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 20
Total : 520
